Picked up a Grandma Bear with straight doors and no UL label with an 8" flue out the back. Need help/advise/opinions please.
There's a back-story to my question, so here goes....
I have a Majestic Thulman L36A Fireplace (Zero Clearance 8") in a house I've been living in for about 15 years. The house has an A frame great room and the chimney going out the ridge of the A frame with a big wooden chase that I couldnt access without roping up. When I bought the house, it had a Little Buck insert in the fireplace, so i slide it out to inspect. The firebrick were cracked and the side plates (whatever you call them) that screw onto the sides were melted. So I sold the insert and installed ventless gas logs and closed off the flue (right or wrong). Then I had the house reroofed and the roofers did away with everything above the roof line and roofed over the chimney.
So, I took the paneling off the inside to see what is left and found some disturbing things. Paper backed insulation has fallen on the chimney, a wooden frame holding it in place in only one place, the roofers didn't cap the chimney like I told them to, and the patch job on the underlayment is subpar. Took lots of pics.
I am open to suggestions on how to make this work if it's possible/feasable. Should I try to use this fireplace with the stove, If so, how? I can fix the clearance issues and will use an elbow to go out of the roof just below the peak.
Should I tear it out and start over with a hearth and black pipe and salvage the Class A triple wall to go through the roof?
Thanks in advance for you comments.
David
![Got a Grandma Bear - Weighing my options on chimney Got a Grandma Bear - Weighing my options on chimney](https://www.hearth.com/talk/data/attachments/157/157221-ebf64267f23c8d7827ddbc0c53e6f8c0.jpg)
David
![Got a Grandma Bear - Weighing my options on chimney Got a Grandma Bear - Weighing my options on chimney](https://www.hearth.com/talk/data/attachments/157/157220-a2c668aec71f58616d644c975997ae95.jpg)
