Hello all; just wondered if anyone had some info or experience with my stove. Tag on the back says it's a Bosca FS500 made in 1984. It's got a brown enameled steel outer skin and glass door with 2 wooden knobs; one for the air control(slider) and the other opens the door by screwing out or closes by screwing in. The door also controls a damper in the top. A secondary tube sits in the center of the firebox with 2 nubs sticking up and the damper plate sits on them. Secondary tube attached to a rod with a 1/4 in. bolt and lock nut. Tightening the door knob pushes the bolt-rod and the tube turns to close the damper tightly.
Picked it up for $100 last fall and it saved out butt last winter with all the -30 nights. Seems well built; the firebox is about 3/8 and damper is a good 5/16. It weighs around the 500 lb. mark. The only info I can get is the company is in New Zealand and they make pellet stoves with the same model number. This one does wood only.
Anybody have a clue?![Got a dinosaur. Got a dinosaur.](https://www.hearth.com/talk/data/attachments/140/140887-23e76d801fcb9d75bde2c259d27bbee6.jpg)
