As many folks might know, I got the old 1988 Defiant-Encore that Elk pulled out of one of the donor stove recipients homes. I'm in the process of rebuilding it, and when done will replace my main smoke dragon that I've been using, and hopefully will then see all the benefits of having a cleaner burning stove.
The main smoke dragon will get moved into the basement, where it will live in semi-retirement - we very seldom use the basement stove, as we mostly just have stuff stored down there, and unless we plan to be doing a significant amount of work that has us down there for a while it isn't worth firing up.
The stove that was in the basement will move outside, where it may get turned into a smoker, or some other form of "yard sculpture"
Elk brought the stove up during the Hearth Party, and we did some serious dismantling on it there, and I've been continuing to pull it apart since. This stove has had a rough life, and I had a lot of problems with stuck bolts, etc. It has been seriously over fired, as the previous owner had allowed the cat to get clogged up, and then ran it in "bypass" mode all the time. In addition the Primary air thermostatic control was broken, and the primary air flap was jammed open with an old pipe clamp.
I've found lots of internal damaged parts, which Elk knows about, and it appears the refractory package may be in worse shape than we thought initially.
Today I think I've finally gotten everything apart that needs to come apart, and am ready to start wire-wheeling and painting the parts, except for ONE big problem...
I had a bunch of stuck bolts, but I was able to get most of them out without excessive damage except for one... :coolsmile:
The bolt that holds the top to the front door frame (one of three that holds the top on) was severely stuck. Even after days of soaking with PB Blaster it still wouldn't move. :coolhmm:
I finally drilled the head off the bolt to get the top off, after having stripped out the phillips recess with an impact driver. :coolmad:
Today I tackled the bolt stub - Broke the drillout tool that I'd been using on the other bolts successfully. Drilled it out to 3/16" and attempted to retap the hole. My cheap HF tap didn't want to cut, so I went in and got one of my better taps, which BROKE in the hole - below flush! :snake:
I got the Oxy-Acetyline torch and was able to melt / burn through the tap and open the hole up a little bit. There wasn't enough thickness there to do a 1/4" thread, and the HF tap wouldn't start, so I wanted to go to the next oversize, but I can't get the COBALT drill to cut! I'm not sure if VC is using really tough cast iron, or if maybe there is still a bit of the tap left in the hole. Not sure I want to put the torch in the hole again though.
Any ideas? Right now I'm starting to wonder about taking the thing to a machine shop and having them put in a helicoil - anyone have a better idea?
Ball park on what a new painted front for that stove would cost? I don't want to spend more money on fixing this one than a new top would cost...
Gooserider
Gooserider
