Good deal on Auger Motor?
Don2222
9,187
Salem NH
Hello
Just saw these on E-Bay for $25 !! You may have to reverse it?
NEW Merkle Korff 4515UI-063 Gear Motor Rotom HM-RGM451 Pellet Stove Auger
(broken link removed to http://www.ebay.com/itm/NEW-Merkle-Korff-4515UI-063-Gear-Motor-Rotom-HM-RGM451-Pellet-Stove-Auger-/330749241765#vi-content)
Item specifics
Condition:
New: A brand-new, unused, unopened, undamaged item in its original packaging (where packaging is applicable). Packaging should be the same as what is found in a retail store, unless the item is handmade or was packaged by the manufacturer in non-retail packaging, such as an unprinted box or plastic bag.
Brand: Merkle Korff
MPN: HM-RGM451 Model: 4515UI-063
These are NEW open box units. May have minor storage wear.
Questions and answers about this item
Q: hello what direction do these spin while looking at shaft facing you and also rpms
A: 1RPM, CCW rotation, viewing from rear. Thanks, JJ
Q: is this a 12 volt or 110 volt motor
A: 120v Thanks, JJ
  • [Hearth.com] Good deal on Auger Motor?
Wow...great deal if someone can use it. For $25, hard to pass-up. And they had 10 left as I wrote this post.
