Goldilocks upper plate plans?
drsimm1776
3
I saw a few folks making or ?buying? a plate to put inside to make the stove more efficient.
Buy where / whom from?
Make i.e .does any one have a sketch with dimensions or plans or ?
Don Simmons
Berthoud, Colorado
Welcome to the forum;
From any steel supplier, ask for A-36 mild steel. Most have a cut charge, but they're reasonable.
Goldilocks has a factory "smoke shelf baffle" that sits on two welded pieces of angle iron on the sides. (Does not need to be fastened to the stove or supports). If you have these supports in your stove, you can see the size of the plate matches the angle iron length. The post with measurements can be found here; Post #120 https://www.hearth.com/talk/threads/everything-fisher.48309/page-5
Goldolocks baffle;
Goldilocks upper plate plans? Goldilocks upper plate plans?
This one was my sole heat source for over 20 years and shows no sign of warping , rust or wear.
