What gloves are you guys using for splitting specifically? I can't seem to find a pair that doesn't fall apart within a month.
I changed to leather gloves since all the other ones fall apart pretty quick.What gloves are you guys using for splitting specifically? I can't seem to find a pair that doesn't fall apart within a month.
I just use regular cowhide gloves, and replace them as they wear out. I had Amazon scheduled to deliver a new pair 4x per year, which was more than I needed, I'd guess every 5th month would've been more appropriate, for my usage. I hate wearing gloves where my finger pokes thru a hole, just slowing me down to reset it, and they're too cheap to worry about dealing with old worn out pairs. Just toss them and slide on a new pair, as needed. There's always more cows!What gloves are you guys using for splitting specifically? I can't seem to find a pair that doesn't fall apart within a month.
lol... I go the opposite way. Nitrile gloves under the wet leather ones. I'm forever having trouble with cracked finger tips due to dry skin, so some hand lotion, nitrile gloves, and then leather are the best recipe. Keeps my hands pretty warm even when wet, and keeps the chapping and splitting finger tips at bay.I typically don't wear any lol. But when I do it's the cheap rubber dipped ones
I've been using Rapicca welding gloves (Amazon ASIN B07DVX6RB6) since September. That's not a long time, but I wear them whenever I'm loading the stove and they seem to be holding up quite well.
No. For splitting I use Majestic brand latex coated gloves or similar. Don't need thick, long, heat-protective gloves for splitting. There's an industrial supply shop not too far away that has them for around $10/pair. Use the same gloves for most general gardening work, and sometimes for light construction work.You split wood with them?
Look like they are worth trying.I use these when splitting and stacking wood, and when hauling brush: https://www.harborfreight.com/safety/gloves/leather-industrial-work-gloves-5-pairs-66287.html
Being double layer they last a while, and when they do fail they are cheap.
that basically what i look for except i try to find the ones that are not split leather i find they last twice as longLook like they are worth trying.
MCR sidekick 16010What gloves are you guys using for splitting specifically? I can't seem to find a pair that doesn't fall apart within a month.
