Glossy black creosote
Crabbypatty
81
Western MA
is this normal? i checked on the chimney while i was shoveling some snow off my roof and the last 6 or 8 feet seem to have a gloosy black ceosote formed, it looks like someone sprayed a can of rustoleum high gloss paint inside the flue! its not thick at all, just a glaze, it is the cold part of the chimney, attic and above the roof.
Nasty stuff.
So it sounds like height of chimney also is a contributing factor. My insert when installed will have a stainless flex liner the entire length, but my chimney is over 30 feet high. Should I be concerned.
My last wood insert chimney, same flex was only like 16-18' up.
Q- Can height concerns be handled with the same wood burning/good dry wood/ advice.?
good links.
Dry wood in a modern EPA stove, interior chimney is usually the best prevention for creosote buildup. Depending on the stove, you might want to consider downsizing the liner slightly to 5.5"? What is the make/model?
The stove is to be a Regency R14, manufactured 1991/2 or so. The chimney to be lined is a ceramic rectangular flue , stone chimney, in an area where a West wind is prevailing.
Is a Selkirk SS flew liner adequate or....?
good links.
I also have a tall chimney (35') and I notice a shiny black coating on the top of my clay chimney pots (this is my first year and i haven't inspected yet (too high!)). Have burned about 2-3 cords (mc ~15-20%) of hardwood.....I suspect I have the nasty hard to remove creosote......my chimney is insulated for 33 of the 35' feet. So, what do we do?
i am gonna try a nice hot fire to see if it has any effect on the glaze. i threw a couple of small rounds on last nite to get rid of them, and they were pretty green, i don't know if that contributed to the glaze....
Can you start a new thread so that your question gets full attention from a larger audience. It's likely to get lost in the creosote thread. I'm not a liner expert but Selkirk and Simpson are major brands. There are some others as well. Is this an interior or exterior flue? What is the interior dimension of the tiles?
Putting unseasoned wood in the fire is a contribution to the chimney-fire burn bank. Not a good plan of action.
