Occo370 said:What does everyone use to clean the glass on the stove
Shari said:"If" you need to clean your glass, wet newspapers dipped in ashes & dried with dry newspapers is the trick.
Shari
Skier76 said:Windex and 0000 steel wool. Works like a charm.
At some time in the burn cycle, when using wood for your heat, primary air WILL be damped, the O2 to the fire lowered, the coals smouldering….ergo some soot. Always.
Adios Pantalones said:No no- 50/50 urine and water, dip paper in that and ash.
Pee on the glass- that's just silly
Mesuno said:Skier76 said:Windex and 0000 steel wool. Works like a charm.
I'm sure it cleans but steel wool on glass can't be brilliant for the surface! The point of the ashes and newspaper method is that it is very very mild on the glass itself while still removing the worst of the soot.
Jags said:Adios Pantalones said:No no- 50/50 urine and water, dip paper in that and ash.
Thats what I use. Works great. Although I have found that drinking vodka the night before makes it a stronger solvent.
Skier76 said:Mesuno said:Skier76 said:Windex and 0000 steel wool. Works like a charm.
0000 steel wool is the "softest" you can get. If you tried it with a Brillo pad, you'd be SOL. 0000 steel wool is a trick I learned when I detailed cars with a family friend. Buffers throw off a good amount of compound and it can be tough to remove from glass. So we'd use 0000 steel wool. I still use it on my vehicles today. It works amazingly well for getting bugs off the windsheild. Just don't use it on mirrors. Mirrors are a bit different and it will scratch that. Again, it has to be 0000 (quad zero). You can find the stuff in the painting section of most big box stores; near the sand paper.
Mesuno said:Fjord - I disagree that sooty doors are just something to get used to. I believe it depends entirely on where the air enters your stove and how it is designed. Yes in many stoves there isn't sufficient airwash, or it is misplaced/misdirected in the firebox.
In our stove the secondary air enters by moving down the inside surface of the glass before mixing with the combustion gases - smoky air should never actually reach the glass in that circumstance and if it does any soot deposits are rapidly burned off. I have on a couple of occasions placed logs too close to the glass. They leave black soot marks but are gone completely in the same evening, usually within a couple of hours.
Yes, we damp primary air, which slows combustion, but you should never be damping secondary air totally as that is just sending unburned BTUs up the chimney as polluting smoke. Airwash is secondary air in our setup, primary air feeds in at the base of the fire.
