I have an old masonry hearth with what was identified to me as a heatilator fireplace surround. Basically, I have steel lining the inside of the fireplace and a couple of vents above and below the mantle to let the heat out. See the attached picture for details.
I like the open fireplace and I have oil heat that I use as my primary heat source. The fireplace had a damper integrated into this heatilator setup years ago, but it rusted out and disintegrated and I've been told I can't get another one. As you can see in the picture, I have the fireplace opening blocked with a piece of foam insulation when it's not in use. I would like something more attractive. Can anyone recommend some sealed glass doors that I could use in this application?
I know the fireplace insert would be the most energy efficient option for me. I may go with a flush mounted unit down a couple years down the road, but for now I would just like to stop the hot air from being sucked out of my house when I'm not using the fireplace.
Thanks,
Jim
![Glass doors for old fireplace? Glass doors for old fireplace?](https://www.hearth.com/talk/attachments/2066804405_b280ab81a9-jpg.179316/)
Thanks,
Jim
