I have a Breckwell P2000i. I took it apart this year to paint some of the brass trim. I cleaned it thoroughly last week and put it back together. I also replaced both gaskets (door and window/glass).
We used it for the first time last night and all worked well. When we went to use it again today the center glass cracked when starting up . AARRRRRRGGGGGGG![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Not sure what could have caused it. It looks like a small amount of gasket sealant may have leaked down onto an area of the crack.
Have the following questions:
1) Any idea what might have caused the crack?
2) I did a quick search and it looks like the cheapest replacement glass for this model is $250. Are there any cheaper alternatives?
3) I thought I followed the instructions when installing the gasket and glass, didn’t torque down too hard on the fasteners. Is there something different I should do with the re-install?
4) If I put a CO2 sensor in the room with the stove and don’t leave it unattended can I run it temporarily (through the weekend)?
