jdege said:What do you use to clean the glass on your stove? I have used just water and a paper towel but was wondering if anyone uses Windex?
Thoughts / Suggestions?
ghandy131 said:Tip I picked up here: damp paper towel dipped in stove ash works wonders!
DneprDave said:I use a wet newspaper, dipped in ashes and then polish the glass with a dry newspaper. I've found that it'll clean anything that the stove can put on the glass, even creosote.
Dave
i use windex also no problems what so everCincinnati Kid said:I've used windex for 15 years and it works fairly well. For more stubborn cleaning issues, I use a wood stove glass cleaner.
You can also use good old fashion oven cleaner in a pinch.
Salty said:wet paper towel directly on the glass when it's cool. Takes everything off with just the grit of the ash on the window. Works perfect.
bigruckus said:jdege said:What do you use to clean the glass on your stove? I have used just water and a paper towel but was wondering if anyone uses Windex?
NO WINDEX...!
jmart said:[quote author="bigruckus" .....I wipe it off at least 3-4 times a day..I like it clean..
