Getting Ready
kentjw
25
Central MA
Getting my York insert ready for winter. Things are going well except the manual says there are two oil ports on the room fan and I'll be damned if I can find them. Anyone know where they are?
If its a fasco motor there here.
  • [Hearth.com] Getting Ready
Thanks. I saw those openings but wasn't sure.
Took both fans apart and cleaned. They were a mess!
Just about ready to go.
Trying Barefoot for the first time - got a good deal last spring.
kentjw said:
Thanks. I saw those openings but wasn't sure......Trying Barefoot for the first time - got a good deal last spring.
Typically, those holes have little yellow plugs pushed into them to keep out dust/dirt. You might want to put a very small blob of Hi-temp silicone over them that can be pulled off at a later time when you want to lube the motor again (during your 1 - 1 1/2 ton cleaning). Remember to use 20w oil..... 3 in 1 in the Blue can (or in the red can if that's all you have) will work just fine.
As for the Barefoots, I think you'll be very happy you bought them.....I got 2 tons myself. :-)
