I am finally ready to get the heat coming. I have an EKO 60 feeding a DIY storage tank. The tank feeds two zones that are heat exchangers to my forced air propane furnaces. I was originally planning on adding 2 thermostats to control the zone pump and the fan motor in the furnace.
After thinking about it I was going to try to use my existing thermostats since they are 2 stage thermostats and "steal" stage 1 for the EKO. I would jumper W1 and W2 on the existing furnace controller so that if the thermostat calls for stage 2 it would initialize both stage 1 and 2 and essentially run on high. ( Basically what I would want for a backup to the EKO ). I would then take the stage 1 (W1 ) from the thermostat to my EKO Zone controller thermostat inputs to trigger the zone valve and the pump.
Has anyone done something similar ? See any problems with the plan ? It would save a lot of time and money in the wiring and thermostats as well as keep the existing walls nice looking with only the original thermostat. Not to mention no retraining of the spouse.
