I looked all over, and I never got any real specifics. So that I don't destroy the electronics in my gas furnace, I need some counsel here. My wood furnace is ducted into the ductwork through the plenum so that there is no possibility of blowback and the gas furnace can run at the same time as the wood furnace. The one thing is it just doesn't get the heat to the outermost parts of the house. What is the easiest way to wire up a wood furnace to activate the gas furnace blower at the same time? My fan limit switch is too low on the gas furnace to heat up enough from the wood heat going into the plenum, (I do have another fan limit switch). I've read three things a person can do, but I need some help understanding how they work or if you know of another way of doing it.
1. Hooking up to the "r" and "g" on the gas furnace relay, but from where?
2. Using the extra fan limit switch, explain where and how without frying something on the gas furnace or causing the gas furnace not to operate as it's supposed to?
3. Using some sort of additional relay. (I'd rather not do this one if possible)
Yes, I realize that I can manually turn on the fan w/ T-stat, but would rather not if I didn't have to. Trying to make this as automatic as possible.
