I just got a new Generac ix2000 (4 stroke, 2000 watt generator). Its a great looking generator, looks and feels very well built! Deflinitely feels better than the honeywell 2000i that I have, which wasnt bad, hard to start, but ran great. Anyways, I havent fired it up yet, but am thinking about breaking in the engine. The only guidance the manual gives is to change the oil (SAE 30) after the first 5 hours, then every 100 hours. I know there are a lot of opinions out there, if it is better to run at no load to slowy mate the pieces, or run it flat out to seat the piston rings. based on the change out at 5 hours, i guess they are anticipating some moderate wear byproducts in the oil fast, then nothing. I found someone on the internet said that after 4 hours the oil was "pretty nasty"
I have to think that it is a generator, made in china, not a fancy race car engine. Maybe the logic to run it hard is true for a fancy engine.... but not for a basic motor. I think that breaking it in more slowly is a better idea. There was some resigual fluid (oil?cutting fluid? it felt oily? in the crank case), there is no soot in the exhause pipe at all, so I am pretty confident it never has been run.
I am thinking:
half hour at no load
half hour at 100 watts
half hour at 500 watts
half hour at half load
I would probably run all of this in the "eco" setting so the rpm is a little lower than full power, likely about 3200-3500rpm), but based on load. Then operate as usual and change after the 5 hour mark ( I have an engine hour meter installed).
Does that sound reasonable?
![generator break in? generator break in?](/talk/proxy.php?image=http%3A%2F%2Fwww.generac.com%2FuploadedImages%2FGenerac%2FPortables%2FIV%2FProducts%2FiX2000.jpg%3Fn%3D8271&hash=d00e90050512209286022e13fd62fb01)
I am thinking:
