Hello:
I have a Majestic RC36 ZC fireplace already installed. I have no issues with it. But I just removed the brick facing that surrounds it and I will now go with just the drywall that was behind the brick so I will now have a flush fireplace. Looks nice.
Anyway, as I was demo-ing the brick, I needed to take a look behind the unit to see if I can frame in some cubby hole type spaces next to the fireplace that will run from floor to ceiling. Again, just trying to customize it a little. So I pulled some of the drywall off next to the unit. My fireplace sits in the corner of the room as most probably do. So I do have some room to add some framing for my cubby holes. In doing all of this, I have five questions...
1) The two walls that form the corner in which the unit sits (behind the unit) are insulated but they do not have drywall covering them. Can I go in and cover these with drywall? I would like to reap the added energy benefit. There is at least 6 inches clearance between the ZC unit and the unfinished wall. I thought I read in the forum somewhere that someone wanted to put a ZC fireplace in a room that was already finished. The answer was that this was okay to do and to just frame around it.
2) Can I also go in behind the unit and drywall the ceiling where the "chimney" pipe extends up and into?
3) During my demo, I found a strip of brass sheet (36" long by 4" wide by maybe 1/16" thick that it stuffed under the unit in front. When I pulled it out, it has a label on it stating that it is there for saftey reasons and to read the installation manual (which I don't have).
4) I will be laying a pre-finished maple floor when all is said and done. Do I still need to have a hearth of some sort? There is no hearth now and the clearance from the floor to the fireplace opening is 11 inches.
5) What type of clearance do I need for the framing of my cubby holes next to the unit?
Regards and Thanks in Advance.
Dan from Detroit
Dan from Detroit
