All I have recently received a Generac IX 2000 inverter generator. It was received as a replacement for my honeywell 2000i which was very hard starting (20-40 pulls). Thanks to all who helped figure out the proper way to break it in. Maybe you can help me figure out why it sucks.
First impressions:
The Generac was much lighter than the honeywell (about 10lbs lighter) It also looks a little better in my opinion. The build quality is also nicer, the plastic is definitely a bit thicker.
I have done some initial break in runs at no load or very light load. My thoughts on these were, its spectacular! It starts right away and is definitely quieter than the honeywell. I have a dB meter.
Sound level:
These readings were taken in my back yard, both generators at the same location and orientation. Ambient noise level is about 50 dB. Readings were taken 1m away from the generator at level with it while they were unloaded. These comparisons are IRRELEVANT to other measurements as the surroundings and measurement distances are likely different. (values measured in dB A)
Honeywell HW2000i
non-efficiency
front - 77
left - 81
back - 83
right - 81
efficiency mode
front - 76
left - 78
back - 80
right - 78
Generac IX 2000
non-efficiency
front - 75
left - 80
back - 82
right - 81
efficiency mode
front - 73
left - 77
back - 79
right - 77
So the generac is much quieter! its very noticeably quieter!
BUT THERE IS TERRIBLE PERFORMANCE
Load testing:
So I now went to load testing. I used 2 different electric heaters, so there were no startup surge loads. One was a ceramic heater that pulled 750 watts and a oil filled electric radiator that had 3 settings, I used the settings for 790 watts and 1490 watts (approx).
The honeywell HW2000i was able to handle all of these loads. Even quick loading it from nothing to 1490watts it had no trouble. It was able to do this at both high and efficient settings. I was able to load it up to 1920 watts with no problem at all!
The Generac IX2000 was another story entirely. On high (not efficient) it should be able to work best. It handled 750 watts, the engine bogged down but was able to recover. Turning it on to 1490 the generator would surge all over the place. The generator would power it for a few second then the overload light would click on and it would lose power, then power would come back. It flickered on and off. It was terrible, voltage dropped down to about 90 volts at times, the HZ was solid at 60 the whole time. power didnt just go on and off, but would fade in and out. This is only 75% of the load and a resistance load at that! Even nursing the load on, slowly going from 750 to 1490 would not help at all. I let it sit for about 5 min as it surged back and forth never being able to power the heater for more than 20 or 30 seconds at a time.
Troubleshooting:
All internals of the generator that I can see are good. I removed the air filter to see if that restricted the engine, no effect. The gas is fresh 89 octane and is stabilized (I bought it last weekend). Tomorrow I will go and buy 93 octane to see if that helps, even though i didnt notice any knocking. I will also spray carb cleaner in the carb to see if that cleans out anything.
Generac Support:
My honeywell takes a very long time to start, at least 20-30 pulls, sometimes way longer. It is very hard to start. I called honeywell to get that looked at under warranty (honeywell has been bought by generac). I have the details of that generator posted in another thread. In short, it was very hard to start, generac said that was a problem and sent me this one as a replacement for the faulty honeywell.
I called generac to resolve this issue and the lady tried to troubleshoot it over the phone, "is the spark plug gap correct?" "I have had it running for 3 hours, I have no idea what spark plug you put in it" She was clueless and no help and said to take it into the service center. the service center is an hour and a half (or so) away, so to drop it off and pick it up, I am in the car 6 hours. Based on previous experience, the $100 service fee will not be reimbursed by generac. Also, looking at reviews of the generator on Lowes's website, it seems like this is pretty common. I don't know if I will bother taking it to a service center... its a lot of money and effort with questionable payoff.
Conclusions:
Bother generators are junk and I would not recommend either.
The honeywell is miserably hard and very unreliable to start. However, once running, it runs great! Just dont be in a hurry to get it going, like I was when my basement was flooding and power was out...
The Generac starts super! its also pretty quiet. But it cant produce enough power to run even 75% load. If you consider it to be a 800w generator, its great, except its huge, heavy, and overpriced.
Honestly I dont know what i will be doing at this point. I hope the carb cleaner cleans out some residue from construction, but thats unlikely. the honeywell will likely be sold as it is still an honest 2000w generator, just very hard to start. I cant sell the generac in good conscience though. I also will not spend the money on a honda, thats just overpriced....
Videos:
Here is the first part showing what is happening to the load inside.
http://www.youtube.com/watch?v=ChF2vEzppxs
Here is the second part showing the generator outside, still trying to run the same load. (for what its worth, I sound a bit funny in the video as the camera is trying to record me while filter out the engine noise I guess).
http://www.youtube.com/watch?feature...&v=J1KbqCf-9ro
I will keep you updated.
Rick
First impressions:
Sound level:
Honeywell HW2000i
non-efficiency
front - 77
left - 81
back - 83
right - 81
efficiency mode
front - 76
left - 78
back - 80
right - 78
Generac IX 2000
non-efficiency
front - 75
left - 80
back - 82
right - 81
efficiency mode
front - 73
left - 77
back - 79
right - 77
Load testing:
Troubleshooting:
Generac Support:
Conclusions:
Videos:
Rick
I have thought about getting an oscilloscope just to see what the waveform looks like, but thats $120 i REALLY dont need to spend
Thats nearly impossible to get these days!
