I was needing to get some wisdom on a situation i experienced last night and what you all do in similar situations. I loaded up my wood burning furnace before bed last night. We lost power 2 hours in. My manual calls for a "non operational" situation where power loss happens. HOWEVER i am instructed to not overload it/keep it small and open the damper all the way to have more heat escape through the chimney (that way the furnace does not overheat). So last night i lose power at 11:30pm and open the door up to try to remove some logs since most were still in there. Oxygen + windy back draft resulted in most the logs catching fire and flames coming out of door. Thankful i shut the door in time but was not a fun experience. All that said. What do you all do/ what would you recommend so i can better prepare for a situation like i had last night?
Thanks in advance
Thanks in advance
