I bought a used champion inverter Genny for cheap thinking it just needed a carb clean since the guy said it ran fine until it sat for a few months...carb clean didn't fix it so I called their customer service line...they though it needed a control board and wanted a copy of my receipt for warranty. I said I bought it used, they asked for the serial number then...they said they could tell it was less than 1 year old by the serial number so they'd still send me the part, no charge if I could install it myself. I said no problem.Over the years if I had a question or needed a part I had great customer service and many times they sent the parts at no charge.
Just a clarification point...most small engines consider a 165cc engine to be more like 5.5 hp...my Champion has a 196cc/6hp, the 212cc Predator is considered a 6.5hp. So you'd have to get into the 225-250cc range for a 7 hp. The 301cc Predator is considered 8 hp.at least 7 hp (165cc) engine.
Good point. I was quoting the ubiquitous 675e from B&S, which I believe used to be listed at 6.75 hp, before they stopped quoting horsepower ratings on their engines. It is something like 162 cc. Some other manufacturers list their 190cc engines at 6.5 - 7.5 hp.Just a clarification point...most small engines consider a 165cc engine to be more like 5.5 hp...my Champion has a 196cc/6hp, the 212cc Predator is considered a 6.5hp. So you'd have to get into the 225-250cc range for a 7 hp. The 301cc Predator is considered 8 hp.
My Champion has a 13 GPM pump and the 196cc "Champion engine" runs it no problem, so a 165cc would likely run a 11 GPM pump just fine, especially if the hi/lo stage shift point isn't set too high.
I'm currently building an old Huskee 22 ton into a custom splitter...4" cyl/24" stroke 1.75" rod, 16 GPM pump, should get me below 9 second full cycle times, according to the cycle time calculator, and a log lift too.I presently have 344cc on my splitter, admittedly a little bit of overkill.![]()
I'm presently running a 16 GPM pump, overspun at 120% for 19.2 GPM. I'm getting full-stroke cycle times around 8 seconds on a Ø4"x24" cylinder. Same Huskee 22-ton chassis, so I can already tell you you're going to need to upgrade your suction line and fitting. If you can find my old thread, I list the McMaster-Carr part numbers for both. You'll also want to upgrade the hard line running between the valve and farther port on the cylinder, I just had mine customer made out of hydraulic hose.I'm currently building an old Huskee 22 ton into a custom splitter...4" cyl/24" stroke 1.75" rod, 16 GPM pump, should get me below 9 second full cycle times, according to the cycle time calculator, and a log lift too.
Gonna have it set up with a 5 HP electric motor and a quick coupling mount system that will allow swapping out for a 8hp Predator gas engine in just a couple minutes, if I want to go split "away".
I kinda figured that would be the pinch point...I was planning on running it as is and see how it works, and how much heat it generates in the oil.I'm presently running a 16 GPM pump, overspun at 120% for 19.2 GPM. I'm getting full-stroke cycle times around 8 seconds on a Ø4"x24" cylinder. Same Huskee 22-ton chassis, so I can already tell you you're going to need to upgrade your suction line and fitting. If you can find my old thread, I list the McMaster-Carr part numbers for both. You'll also want to upgrade the hard line running between the valve and farther port on the cylinder, I just had mine customer made out of hydraulic hose.
