Hi folks, got a bit of an issue with one of my outside fireplaces. It's a masonry fireplace equipped with a propane log set (Real Fyre G4-30PX-SS + SPK26P), and the original installer (for prior owners) did some hokey stuff with the construction.
They ran a plastic line thru conduit under my patio into a cavity below the flagstone fireplace floor, terminated in a steel (not stainless) fitting, and transitioned to a corrugated stainless line. This corrugated line goes thru a somewhat circuitous route under the floor of the fireplace, and then up thru a hole sawn in the corner of one of the flagstones, where it is terminated with a brass quarter-turn valve. The gas log set connects by another corrugated stainless line to this valve.
Transitioning from one line to another (plastic to stainless) in a blind cavity under the fireplace floor has been flagged as a safety hazard by my propane supplier. This caused me remove a section of the fireplace floor to investigate (a few minutes with the pneumatic hammer), which is when I found the fitting(s) making the transition were corroded almost beyond recognition. Good thing I caught it when I did.
I'd like to pull a new line, at least from end of conduit near regulator, up thru the fireplace floor, into the firebox itself. There I can either connect it directly to the gas burner supply line, or thru a valve if needed (regulator shut-off is only two dozen feet away, at other end of conduit). But I'm debating the best line type to use, and what will be needed to terminate either end of the line.
I'll include some photos, which might help.
![gas fireplace supply gas fireplace supply](https://www.hearth.com/talk/data/attachments/298/298108-a464b3558ec14fed71521fbb431ee0fd.jpg)
![gas fireplace supply gas fireplace supply](https://www.hearth.com/talk/data/attachments/298/298105-e4f4eb6b74f9a063ece951fce681d153.jpg)
![gas fireplace supply gas fireplace supply](https://www.hearth.com/talk/data/attachments/298/298110-8eced1e2f2e6eb367626b3c65d1c0635.jpg)
![gas fireplace supply gas fireplace supply](https://www.hearth.com/talk/data/attachments/298/298109-5f7c17d42d5b7b2405f16a1e6bc1468c.jpg)
![gas fireplace supply gas fireplace supply](https://www.hearth.com/talk/data/attachments/298/298106-aca46a0aed2b5c6131b58200f02bef8d.jpg)
