Now you know why I prefer an electric chain saw where ever I can get an extension cord to reach. Just lay out the cord , plug it in & pull the trigger. presto,your cutting wood.![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
a couple of notes about electric chain saws .
pros
electric saws don’t vibrate and are easy on the opperator.
They start right up first time.
they are light wieght.
Cons
They are not heavy duty. They will not tollerate any abuse.
You must let them cut at their own speed and not force them at all.
they are slower than a gas saw to cut but don’t take 30 minutes of pulling & swearing to start.
WHAT YOU SHOULD KNOW ABOUT ELECTRIC CHAIN SAWS
They are direct drive from the electric motor through a plastic reduction gear that , being plastic will break off teeth and ruin the saw if any force stops the chain from free turning.
#1 Rule ! Don’t ever pinch an electric chain & bar in a log & when you do, let go the trigger immediately so that you dont break the plastic reduction gear. Use a plastic wedge to get the saw unpinched.
the electic saw does not have a clutch to slip if the chain gets bound or pinched; it is direct drive instead and so the reduction gear breaks instead of the clutch slipping.
even the chain break can cause the plastic reduction gear to break a tooth so dont use the chain break unelse you really have to.
#2 rule --- when the electic motor gets hot, stop cutting & let the motor cool down . Its time for coffee & , so take a 20 min break. electric motor winding are thin & they can get too hot and burn out. loading the chain by pressing into the log slows down the electric motor which will pull more electricity to try to speed up and get hotter faster.
IT IS A REALLY BAD IDEA TO LOAD AN ELECTRIC CHAIN SAW because it heats up the motor way fast & strains the plastic reduction gear looking for a weak tooth to break off the gear.
So if you want to trash your electric saw, that is how to do it.
I believe that the smaller & cheaper electric saws are the best cut for the buck because the 4 hp electrics still funnel all that power through the same cheap plastic reduction gear. which will take more of a beating with 4 hp & break sooner than it does with 1.5 hp.
I have a 10 in poulan electric limb trim with 8ft handle , a 12"remington elec., a 14 in remington electric, a 14 in wen electric, 3- 16 inch mccolloch electrics & a 18 inch 4hp poulan pro electric that I just bought on sale.
They all still run after 2 to 4 years of cutting 6 to 12 cord a yr.
& I bought them all used from craigslist except for the 10 in poulan & the 18 in poulan which I bought new.
Of the small saws the wen seems to cut the fastest, closely followed buy the mccullocks, with the remingtons & poulan being slower.
The 18 in poulan 4 hp is quite powerful & fast, but I suspect that it being new with a new factory sharp chain has a lot to do with its speed of cutting.
I resharpen my own chains with the 5/32 file & holder , but sometimes the chains don’t cut so good & some times they cut great. I guess it depends on my mood when I resharpen them.
I also have 2—14 in,33cc homelite gas saws, the first was a solid body & the second vibration mounted handle & a 20 inch homelite 45cc gas saw vibration mounted handle & a sears 18 in gas that runs if i squart 2 cycle fuel into the carb but wont carburate gas into the engine on its own.
I only use to gas saws where there is no electricity or if I an cutting a big tree trunk where I expect to have a good chance of pinching a chain.
IF ANY OF YOU GUYS KNOW STUFF ABOUT ELECTRIC CHAIN SAWS or have questions, PLEASE ADD TO THIS THREAD.
pros
Cons
