GAS CAN ASH CAN ?
rustynut
377
mid mich
having a time finding an acceptable metal can for my ash.......
had an idea
got a military style gas can that is a pain to use for gas
got to hold it up for ever while pouring fuel
thought it might be interesting to use for an ash can, cleaned and modified of course
anyone got any ideas on how to clean it ?
might make an interesting conversation piece as well
thats what i was thinking
some liqiud dish soap and h2o
soap as reqd
think i'll give it a shot and see what happens
finished product should offer some good pics
5 gal gas can sitting next to the stove
lol
thanks
get it good and dried out set it out side with any vents or filler tubes open and drop a match in. that should burn off any fuel vapors. Then you the soap and water, should be good to go after that. Note to self that is a pretty good idea I might have to keep and eye out for one at some yard sales this spring
lol
just something about dropping a match into a can full
of gasoline vapor that gets me going.............. ;-P
Why make it harder than it is...an ash bucket with cover can't be more than $20 at your nearest hearth store. Hard to believe there's no ash buckets in mid MI...that's a big wood burning state.
I went to the local building supply place looking for a metal bucket to buy. The guy gave me an empty acetone 5 gallon can with a metal lid. They must use it for cleaning or something. It has a plastic piece on the handle for easier carrying which I removed, and a plastic spigot for pouring which I removed and replaced the hole with a piece of flat metal duct.
Total cost was nothing. Guy said they have them sitting around and normally have to pay for special disposal.
ash cans?
went on a search 2 times
had a couple of choices
35 gallon metal trash can or $60 for a comercial one
neither one grabbed me
think i'll look at this gas can project
you can wash gas off your hands so i should be able to clean this can
got a small metal bucket that will do for now
thanks
Are you talking about the classic 5-gallon "Jerry Can"? If so, it seems to me that it'll be a real PITA to get the ashes into it through the ~3" spout hole, unless you're thinking about cutting the can apart so you can lift off the whole top of the can. Maybe I'm not picturing accurately what you have in mind. Rick
Yeah Rick...that's just what I was thinking too...and they're also a pita to use even when you use them for what they were made for.
Whatever you decide to use for the ashes For Petes sake put them outside as soon as you empty the stove. They will release lots of CO through the night which is not good.
Hey Rusty, fwiw I found a pressure cooker works very nicely . Second hand for 5 bucks. Fits inside stove to help contain flying ash.
We still use some WW2 surplus Jerry cans for filling our boat. Check Ebay, they go for a good amount. Maybe you can sell it and buy the ash can of your dreams.
Matt
When I was young our neighbor wanted to repair his car's gas tank. They removed it from the car and rinsed it out several times.
Filled it up several times completely with water. Then he took a very long rod with a burning rag on it to test it and it still blew up.
I would not use an old gas can for ash.
yes one of those ww2 jerry cans
anyone that has one knows how they are to use
that no lead nozzle takes forever to unload the can
i was originally going to use a plastic funnel thru the fill hole for loading the can
figured it might be a little difficult to unload the ash
switched to a metal funnel instead :-)
no really
cut the top 2 or 3 inchs off and hinge it
maybe flange it
add a clasp or two of some type on the other end..............
split this said:
I use something like this http://www.amazon.com/Metal-Refuse-Container-6-Gal/dp/B00002N856/ref=pd_sbs_k_8
Then I put a approx. 2 gal. metal pail inside. I put my ashes in the small pail then put it inside the larger then take it
outside. Then pour some water on the ashes let it soak then dump the contents in my garden. Both cans I found at the dump.
Thats exactly what I use in the 10 gallon size. The hardware store had 2 variations, one was a much heavier gauge then the other so I got 2 of the heavy ones and find that carrying two full cans at the same time is easier then just one due to ballance. The handle keeps the lid from blowing away in the wind and I have them set up 25 feet from the house on those cement patio blocks so they don't freeze into earth.
I did use the larger 30 gallon steel cans but they got mighty heavy when full and the handles on each side always ended up breaking off. I have a pit dug way out back for dumping so the smaller cans work great.
Gary
no really
maybe flange it
2 of ours flow fast, one goes slow. It has to do with the breather. Maybe you could add a new one? I'm not sure what a no lead nozzle is. Ours followed my father home from Vietnam, maybe they are different? It's hard to find a more durable can... I wish you were closer. I'd offer to buy it. I'd love another one.
Matt
Hearth stove ash buckets aren't too intrusive and will sit nicely out of the way on your hearth pad.
[Hearth.com] GAS CAN ASH CAN ?
...and just suppose you get a chimney fire...well you can use the convenient bucket of ashes to smother the fire while you wait for the first responders.
Now when this bucket fills up you can dump half of it out into an outside container where they can eventually be use in the driveway for traction or the garden as a fertilizer supplement.
Nice can Savage but the rule we live by here is "Out of the stove and out of the house"! Even after the ashes are removed they can still be producing CO2 gases and heat.
I also find the process of transfering from the ash pan to a can inside the house but outside the stove adds an additional coating of dust inside.
Most of our wood stoves do not employ a seperate ash pan but for those that have one, empty it outdoors!
Gary
Gamalot anything that burns...even a candles on a birthday cake will produce CO.
Next time you dump the coals by the stove door...not the black charcoals in the back...the red ones in the front don't put the top on. The hot coals will not trip the CO detector. For the last 2 years ago were using the Kidde voice 2 alarms in 1.
I suppose there's no harm in being overly cautious but in an emergency I have decided I want the ashes readily available.
My ashes all get dumped through the shaker grate and in to the ash pan. I don't disagree with you at all but getting from my ash pan and in to the ash can inside my home would be a very dangerous and dirty proceedure.
I guess it depends on the type of stove you have and how you have it set up.
I pull the full ash pan out and walk it out the back door to safe dumping grounds.
Gary
OK now I understand where your coming from. When we had our Shenandoah we'd empty the ash pan out side because of dust issues. But we always had ashes in the ash bucket sitting by the hearth in case if a chimney fire. With the new stove you have to stay on top of the ashes daily and remove a couple shovels full. With the Shenandoah we could go 4 maybe 5 days...and there's no way I'd pour them much into a bucket indoors.
