Since I have been running a WHS 2000 flat-out for two months, I haven't had a good chance to assess how much standby heatloss I have, until this week. Since I have been scratching my head with the short circuit issue that I've posted about, I was doing some rework yesterday and I didn't pull any heat out of the GARN. Over the course of about a 12 hour period, I lost somewhere between 5-7 degrees in the tank (depending on which sensor/gauge I read, I have three monitoring the tank). Tank temp started around 135, and I think the ambient air temp range was 25-32 over that same time period.
If I extrapolate, I could be losing as much as, if not more than, 10-15 degrees over the course of an average winter day just from the tank, which was a surprise. And since I try to go as high as 200*, I've got to be losing even more than that 10-15 when I am at higher temps.
The unit is insulated similar to what I sense others have done. Unit sits in a corner of a shed that was constructed for it, with the two outside walls insulated with about 4" of spray foam. The third interior wall is insulated with R-21 pink. There is a framed 2x10 ceiling at about 6-1/2' over the top of the unit, and that is insulated with R-30. All walls are covered with firecode rock, seams taped. The empty spaces between the tank and the walls are stuffed with more pink stuff. I do have about 30" between the back of the unit and the rear wall. I had to make a 90* turn with the exhaust and since, per Martin, that needs to be inspected and cleaned annually I left myself a little bit more room back there to work in. Since I do have that space, and since I've got heatloss in the space due to the cold air intake duct and the airgap around the class A exhaust thimble, I went ahead and steel-stud framed a wall right up against the rear of the unit and insulated that with 3-1/2' pink stuff too. There is an access hatch for that space, but that is insulated fairly well too.
The only area that is not "finished" is the front of the unit - it is insulated with 3 1/2 " of pink stuff, but I don't have the firecode rock on it yet (yeah, I know, that's a hazard and I will get to it). So I am sure I am losing more there than any other area (lowest r-value, and drafts due to the lack of the sheetrock). The manway cover is also a little bit of an issue, I've been fighting with it to keep it from letting small amounts of water vapor escape into the insulated cover I made for it.
Aside from those two things, I thought I had this all wrapped up nice and tight. I was expecting standby loss, just not so much. 10% or more over the course of a day seems high ... what do other GARN owners see?
Tom
Tom
