I posted this over at Garn, but did not get a response. Thought I might try it here.
Slowly but surely my project is starting to take shape. On the Hearth Forum I have followed the progress of several Garn installs and I have noted with some interest that the steel studs that people are using do not seem to meet the requirements in my install manual. Commonly, the sheetrock will not fit (5/8") when placed on a 3.5" stud and so they go for a smaller size stud or thinner sheetrock. From the pictures and the stories, it also becomes obvious that the gauge of the steel is not 18, but more likely the lighter 25 gauge sold at big box stores. I am not saying that they are doing it wrong. These are competent heating guys and I would not presume to criticize. But it raises a question. Some of these guys have the studs mounted right up against the unit without any protection for heat loss through the studs. Is it essential to place a thin layer of rock wool between the studs and the tank. If so it will exacerbate the thickness problem and the stud sizing. Do you have to use 5'8 rock if you can use something else that is non-flammable like concrete board or Hardi backer board? That might be thinner but harder to tape for fire purposes. Will that impact warranty? Right now, I am looking at pictures of installs that have the metal studs up front and on the end, but wood studs on the side and I am not sure that is kosher.
My original plan is to insulate with vermiculite inside steel (18 ga.) framed walls with 5/8" sheetrock, but if I could use alternate materials that I have on hand such as OSB on side framing, wood studs on the sides, concrete board in place of sheetrock, etc.it would make things easier for me. I have no intention of sacrificing safety for economy, but if there are solutions of equal value then I am all ears. Any thoughts?
