I think to replace the temp senders, level switch, fan motor, and a couple odds and ends with the modern equivalvents might cost you $2000 max, if you can build them yourself (the older models like this just had a timer and the high temp safety and low water cut out, which would be easy to build) you would spend less than $1000 probably.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
