By the way, temps get down to -20 F in winter in my area and I have no problems getting the garage warm. The biggest hassle is dealing with the water melting off my vehicles as the ice and snow that inevitably collect under them melts.
DRAIN
![hmm ;hm ;hm](/talk/styles/default/xenforo/smileys/hmm.gif)
Wow. Mine just run out to the wetlands on the adjacent property. Nothing ever goes in there other than snow melt, and a miniscule amount of road salt.Not legal unless its hooked up to wastewater treatment system.![]()
Better hope they are not using waste oil for oiling down the roads.Wow. Mine just run out to the wetlands on the adjacent property. Nothing ever goes in there other than snow melt, and a miniscule amount of road salt.
In unrelated news, our township just sprayed what must be over 10,000 gallons of oil on our road, and spread loose gravel on top of that. The day before a substantial rain storm, that likely washed a good fraction of that oil into our yards and watersheds. I noticed they did another road, just a few miles away, which would have used twice the oil of my own. And someone is worried about my garage floor drain?
Some of us think clean air and water etc. Are nessecary to live freeWhat happened to "Live Free or Die " ?
Or...." Don't ask, don't tell" ?
Well yes and no some things that would go down that drain would be much better fun through a treatment plant some would not. Really if all the drain is used for is drainage of snow melt and water dripping from the car it would be no issue. But i have seen idiots dump all kinds of stuff down their garage drains. But chances are those guys would just dump it on the ground otherwise so who knows which is better.Not arguing with your point, but it’s not applicable to the case of peakbagger’s floor drain complaint. Hooking a garage floor drain to a wastewater facility creates more problems than it solves.
I live in very rural pa and we have waste water treatment facilities. No not everyone is serviced but a large percentage are. I know nothing about the systems in place in nh but i would never want to go to a private sewage system. And yes like i said if it is just snow melt and rain draining off the car it makes no difference at all. But many people dump crap down their garage drains. And if they are forced to hook to their septic system they wont do that because it will destroy their system. The point is if people didnt do stupid crap there would be no need for codes or regulations but unfortunately many many people do stupid sht all the time. Because of that we need codes."Live Free or Die" state is rural where Mr. PeakB lives. No "wastewater facility" in rural New England. This ain't Philly suburbs.
So...drain leading to a gravel sump, outdoors to a downslope to nowhere, a kind of "french drain" system surrounding the garage. Choose where the drain wastewater goes in a rural environment. No sewer systems in the country Ash.
If there is no harm to the land or neighbors , drain away. Where do you think all that salt melt on highways runs off to ?
And, that mini split of yours is not cheap $$$, uses high carbon refrigerant and materials, and is a high tech repair when it fails. And, mini splits go to resistance heat (very high consumption) below +/- 10, common in up here. Drain the melt. Don't ask, don't tell.
Hah... you make too many assumptions. The smallest property in my hood is 4 acres, by zoning. Most are over 10 acres, and half our township land space is single properties over 100 acres. I’ve spent quite a lot of time in New England, and never felt any of it was rural, but whatever... it doesn’t matter. Thump your chest and and call yourself “rural”, if it makes you feel better."Live Free or Die" state is rural where Mr. PeakB lives. No "wastewater facility" in rural New England. This ain't Philly suburbs.
So...drain leading to a gravel sump, outdoors to a downslope to nowhere, a kind of "french drain" system surrounding the garage. Choose where the drain wastewater goes in a rural environment. No sewer systems in the country Ash.[emoji57]
Our "septic system" is NOT a "wastewater facility", it is a septic system with what we call a septic field.
The water from melt in the garage will just evaporate as the stove burns and help to humidify the space. If it is extreme amounts just get a garage squeegie and once fully melted, open the garage door a few inches an push it out and close the door. If the floor was put in with any thought at all, it should have a pitch toward the door for drainage anyway. The water that drips from your car and all the salt came from the outdoors anyway did it not? How many mega-tons of salt run off into streams and lakes every year? Salt is natural, and as it turns out necessary.
Yes it is natural but it is naturally deep under groundOil is natural too. So are many poisons.
I have built several shops and never sloped the floor as you would with a residential garage.
Well you are right not always there are tar pits etc naturally. But they are very rare.Not always. Are you too young to have watched the Beverly hill billies?
Again if it is just snow melt goung down the drain it doesnt make a difference because that would have ended up on the ground anyway. But that isnt all that gets put down garage drains.The water from melt in the garage will just evaporate as the stove burns and help to humidify the space. If it is extreme amounts just get a garage squeegie and once fully melted, open the garage door a few inches an push it out and close the door. If the floor was put in with any thought at all, it should have a pitch toward the door for drainage anyway. The water that drips from your car and all the salt came from the outdoors anyway did it not? How many mega-tons of salt run off into streams and lakes every year? Salt is natural, and as it turns out necessary.
All of the shops i have built or helped to build are sloped in the area inside the overhead door but the rest is flat. But that comes down to the type of useage and personal preferenceOil is natural too. So are many poisons.
That's the way mine is, too. Front 20 feet across the full width is sloped toward front doors, back third is sloped toward side door. Makes a little extra work of leveling big machinery, but at 1 inch per 10 feet, it ain't a real big deal.All of the shops i have built or helped to build are sloped in the area inside the overhead door but the rest is flat. But that comes down to the type of useage and personal preference
Chip seal. The most horrible roads ever.Wow. Mine just run out to the wetlands on the adjacent property. Nothing ever goes in there other than snow melt, and a miniscule amount of road salt.
