Hello, I use the fire place at my home a lot and decided a wood stove insert would be best. I purchased flexible liner with insulation and cap and all. The stove is an older insert that has a rectangle exhaust top connection.
I installed the liner and adapter for rectangle stove exhaust to circular liner. Where the liner is suppos to attach to the stove there is roughly a 1” gap as the stove doesn’t sit far enough back for it to line up perfectly. I am already roughly 2000$ into the install and tested the stove with no exhaust leak into the room or at the top of the chimney. How severe is it if the chimney liner and stove are not air tight at the stove exhaust? It has a strong upward draft through the liner and The insert is sealed around the opening of the fireplace.
Thanks for any advice
