Hello
Many times when the Harman ignitor dies it shorts out and blows the circuit board fuse.
This fuse is 6 or 7 amps and when it goes, the stove has no power. Since there is no power the stove cannot be started manually.
Therefore, If it had a seperate fuse like other brand stoves, the ignitor fuse would pop and the stove could still be started manually.
An inline fuse holder from Home Depot can easily be added in series with the yellow ignitor wire in the back of the stove. An AGC 5 amp fuse that must be purchased seperatly can be installed.
Any damaging short caused by the ignitor will blow this fuse. The stove will still run fine and can be started manually.
Pic 1 - Fuse holder and Fuses
Pic 2 - Original Ignitor wires coiled up.
(Note: splice into right side of coiled yellow wire closest to the control panel. This way the wires can still be pulled into the air inlet tube for ignitor replacement when needed)
Pic 3 - Quick disconnect clips from Home Depot used for connections. Easy to remove or change.
Pic 4 - Fuse holder tucked up and away from any heated parts, but can easily be pulled back down for servicing.
