All of a sudden no power to the XXV. I looked for loose wires - none. Evidently there is a 6A 250V fuse inside the control and it was burned out. Anyone have this happen ?
My XXV has been in use less than a full season, without any problems. But if you have to go to your dealer and find out the cause, please post the answer. I guarantee I'll be at least one interested reader. (The Owners Manual doesn't seem to have any info on your problem.)
I find it absurd that after 52 posts no one has ever heard of this. I guess pellet prices, the longest pellet and other bs is more important - incredible. Is there a technical section that I'm unaware of ?
well, its tough to troubleshoot an electrical issue on the BB. A blown fuse? Could be a bad connection in the stove, a circuitboard issue, a bad fuse, BUT could also be a house wiring issue, power spike, etc. Not an "issue" thats common or one Im aware of. I guess I'd suggest getting another fuse and replacing it....see if it happens again. If its a stove issue, and the thing blows right away again, Id get the dealer out there for warrantee work. If its intermittent, and doesnt happen right away, like I think you'll see, its most likely NOT the stove but a power issue, and thats NOT covered under warrantee. Thats your problem to solve....dont expect the dealer to troubleshoot home wiring or power supply issues. Good luck.
When a fuse blows there is a serious problem. The first thing is to contact your dealer.
Was the stove running, in start up or cool down as the fuse blew?
Is the stove on a surge protector?
Check your power cord make sure it is not fraid, pinched or cut somehow.
I'm a XXV owner as well. Been running since January. I agree with lousy, replace the fuse and fire it up. Maybe put the stove on a surge protector as well. What happens? Does it blow again?
If so, call the dealer and get him out there. I got a fair amount of hands-on, but I would let the dealer handle something like this.
See, I wouldn't go on this site expecting someone to fix an electrical problem on my stove. I'd call my dealer. However, in your case you've probably worn out your welcome.
