Anyone have any experience with the Fujitsu hyper heat heat pumps? We finally got a quote from a good installer that is within our price range and they want to install 3 Fujitsu multi zone hyper heats to 8 indoor units.
Are you going to use these for AC too? I’ve been doing a lot of HVAC research. I’m not sure which name brand is as important as install. I would do almost anything to avoid a condensate pump. Know that cleaning the indoor units is not as simple as just vacuuming them out. And they really are not great dehumidifiers.Anyone have any experience with the Fujitsu hyper heat heat pumps? We finally got a quote from a good installer that is within our price range and they want to install 3 Fujitsu multi zone hyper heats to 8 indoor units.
3 multi zones with 8 heads? This setup is most likely ridiculously oversized for a typical New England home and will lead to terrible efficiency. Read this podcast with Dana Fischer who works for Mitsubishi in New England.Anyone have any experience with the Fujitsu hyper heat heat pumps? We finally got a quote from a good installer that is within our price range and they want to install 3 Fujitsu multi zone hyper heats to 8 indoor units.
I don’t think you can make that statement without knowing equipment specs and house specs. Sized for heating three 18000 btu units would be reasonable.3 multi zones with 8 heads? This setup is most likely ridiculously oversized for a typical New England home and will lead to terrible efficiency. Read this podcast with Dana Fischer who works for Mitsubishi in New England.
The Multi-Zone Heat Pump Issue - GreenBuildingAdvisor
In cold climates, multi-zone heat pump systems (or multi-split systems) are developing a reputation for under-performing in terms of energy efficiency. In a nutshell, this happens when you ask a […]www.greenbuildingadvisor.com
Or some kind of giant house with many levels and small rooms.3 multi zones with 8 heads? This setup is most likely ridiculously oversized for a typical New England home and will lead to terrible efficiency. Read this podcast with Dana Fischer who works for Mitsubishi in New England.
This is going to supplement our oil heat. Basically the heat pumps will run until its around 20 or so outside then the oil will take over. So they aren't pushing for the ultra cold weather, because I'm not going to be using it then. We had a couple quotes to run vents to the 4 units upstairs and I liked that idea more, but it was in the end way more expensive.I think a lot of HVAC firms regard Fujitsu's as the same quality and reliability at Mitsubishi's. Mitsubishi has been at it for longer. There are other brandlike Midea that are probably good but regarded a bit lower. I find the Fujitsu dealer tend to be more minsplit oriented while Mitsubishi are larger dealers that carry multiple lines or techology. The local Fujitsu dealers tend to push their very cold weather operation, I think they come stock with pan heaters while its an option for Mitsubishi's.
I am less of a fan of multihead units due to early experiences with them. They are a lot more complex with more parts to break down.
Yes for heat until it gets down to about 20 then the oil will take over then for AC in the summer. I took a look at cleaning the inside unit online, and I agree it looks like a pain in the ass, but it is what it is. As far as the AC goes we probably won't have it set to lower than say 75 all summer. Also assuming that they can just be run in fan mode, I'll use the one near my stove to push the heat around in winter.Are you going to use these for AC too? I’ve been doing a lot of HVAC research. I’m not sure which name brand is as important as install. I would do almost anything to avoid a condensate pump. Know that cleaning the indoor units is not as simple as just vacuuming them out. And they really are not great dehumidifiers.
That aside when installed correctly they I have not heard much bad about Fujitsu. Is a ducted system not at all practical?
BTW, I would strongly suggest putting a high quality surge suppressor on any house including one that is getting mini splits installed. The Midnight Solar SPDs have a good reputation. Electronic control boards frequently are cooked by short term load surges that are heard to detect.
I'll ask about surge suppressors. I live kind of in the woods and the power goes out a few times a year.it's not a requirement yet but the companies strongly say they want a surge unit on the outside disconnect. the one that most say they want is for outside use but in my opinion not as good as the ones that are mounted next to the inside service panel.
This is good to hear. I'd imagine that in the past 10 years they have made some improvements too.We have several in our neighborhood including a 2 head install at a close friend's house. They are very efficient and heat well in our climate. The only thing that has been serviced on my friend's is that a power surge during a big storm blew out the electronics many years ago. Surge protection was put in and it's been working great for about 10 years since.
Well like anything that has technology repairs can come up. My buddies Mitsubishi had a motherboard repair. Luckily it was still under warranty. So far 5 years no issues with our Fujitsu.They installed a Fujitsu in one of the offices at my work and that thing was constantly getting repaired. They eventually removed it and installed a Mitsubishi. Doesn't speak to the quality they're supposed to have.
Most home units including mine have the condenser located on the side of the house away from any drip line. My unit is easily over two feet away from the shingles. Quality contractors put them on stands on a pad so they are well off the ground. That is how my unit is installed. A foot of snow won’t effect anything. In the five years we had the unit, a few storms brought well over 30” of snow and never had a drip pan issue defrosting the unit. There is no way a foot of snow could even get in the drip pan because of the tight clearances of the condenser. What you need to do is shovel “around” the condenser which takes less that 10 min. to do. My contractor told me to this with heavy snow. I make a path with my snowblower to the unit and then shovel around it quite simple.As I have mentioned before, I have seen a lot of crappy installs even by so called pros. They usually mount the ground unit way to close to the ground directly under the drip line of the roof. I had a 5 ton commercial system at my last job project with those two issues. I added it to the punch list but they cut me loose before it was closed out. It was in central Mass but it still snows some years and it rains plenty. It was a the equivalent of 3 story Industrial building with large shallow pitch roof so lots of water gets dumped off the drip line. I see commercially installed units all the time buried completely with snow. Contrary to popular belief a Fujitsu pan heater is not going to melt a foot of snow very quickly especially when a plow pushes snow over it. I have seen units pushed almost off their bases by snow plowing. I know most facilities do not want them mounted on the walls due to potential for vibration. The contractors really do not care, they get paid to install them when new and fix them as they get old and its lot easier to just blame the equipment.
Also as mentioned before, put a quality surge suppressor with low clamp voltage on the panel (or subpanel if it is a large facility). Lots of dirty power comes in from the utility on occasion and adding distributed generation is not going to make it better. Even if the power is perfect coming in from the utility, plenty of opportunities for internal surges.
