Hello
I saw the first 2 pics at the local Ace Hardware store and thought it would pretty but I would need one of those new slim line routers to cut the post channels. So I picked up the lights and wires on the day of the 20% off anything you can fit in a bucket and brought it all home! I also got a nice Makita Router and 3/8" bit to cut approx 1/4" deep channel with the straight edge guide that comes with the router.
The connector block with clip leads is easy to install but I drilled a hole in the back of them and mounted them with a wood screw instead of double sided tape for more security. One of the spike connectors did not make good wire contact when I fired up the lights so I had to go back and make sure it pierced the wi properly to make the electrical contact.
The 12v LED lamp is good for approx 24 years and the motion detector I already mounted above the garage will only turn the lights on when needed so they should last a very, very long time.
The only draw back is that becaust the low voltage transformer takes a few seconds to warm up before the LEDs lite, so when I drive into the driveway the cap lights come on 30 seconds later. That is how long it takes me to get to them so it works fine for me.
Anyone else try this? Any tips and how do you like them?
Pic Store Demo 1-2 -- Ace Hardware Store Display
Pic 1 - Post Cap LED in aluminum cap and connector block
Pic 2 - Choosing location to start routing
Pic 3 - 6 Routing channel 3/8" wide and 1/4" deep for 16 Guage Low voltage 2 conductor wire
