Hello, I'm setting up a used Winslow PS40. It's working aside from needing to buy the outlet venting, a convection switch, and fresh pellets, but I'm curious about this pull lever on top at the front of the stove in the decorative grates. Is it the draft adjuster? The manual I downloaded says it is in a different spot ("at the left side of the stove directly in front of the combustion blower") but not seeing it there and wanted to double check. I figure it probably is since there are variations in models.
TIA!
![damper.jpg damper.jpg](https://www.hearth.com/talk/data/attachments/267/267539-a67129857af4bfa4bc82c1d8852797e6.jpg)
TIA!
