How are you other Froling 30/50 owners placing your boilers? Directly on the floor or raised up on some sort of concrete blocking ?
I made a pad using patio slabs on a bed of mortar to level and secure them to the floor, two 24x24 slabs worked for my smaller boiler. You could look at using 24x30" slabs, the 30" wide would work for the width but there would be a gap of 2" between them along the length which could be filled with mortar to give a continuous surface. The house keeping pad keeps makes sweeping the floor easier and prevents hitting the bottom of the boiler with boots, step ladders etc.
View attachment 175396 View attachment 175398 View attachment 175397
The height thing, especially since I plan to keep my boiler for a log tie (i.e. as I get older) was the reason I put mine on some 8" blocks. This raised my lower chamber making it easier to clean out. I forget your thoughts on using an ODR to control flow temps but as you are redoing your system I will again wave my low flow temp banner - this is my 1st year with that kind of set up and I could not be more pleased.Thats a nice clean look, also should make it a more comfortable height for the lighting door.
Looks like you are getting some smoke escaping from your primary door.The height thing, especially since I plan to keep my boiler for a log tie (i.e. as I get older) was the reason I put mine on some 8" blocks. This raised my lower chamber making it easier to clean out. I forget your thoughts on using an ODR to control flow temps but as you are redoing your system I will again wave my low flow temp banner - this is my 1st year with that kind of set up and I could not be more pleased.
I do use a 2/3 step ladder for the cleaning. Like you I have an "automatic" tube cleaner so I really only clean the tubes 3 or 4 times per year. On my Effecta 35KWb I had the "automatic cleaner" that I would lift handle about 5 times per fire and it worked fine. The 60KW cleaner is tied into the door the door. Originally I was having issues with rising flue temps, now I open/close the door about 5 times before each fire and I am back in good shape.Looks like you are getting some smoke escaping from your secondary door.
The tubes are under a cover on the top of the boiler, a step ladder is needed to lift the turbulators straight up. then brush the tubes and reassemble. this process takes less than 15 minutes for my boiler, only 4 tubes. i clean the tubes after every cord. i have the maximun flue temp set to 350F so that if the tubes get dirty I will see the boiler reduce output to keep the flue temp down which is a cue to clean them as well.With the boilers being raised how easy are the fire tubes to get at for cleaning? Looks like a short ladder would have to be used.
That is an operator issue not a machine issueLooks like you are getting some smoke escaping from your seconday door.
I put my shop vac hose up near the top of the tubes so that when I extract the brush the vac much of the ash gets sucked up.On the floor...and using ladder to clean tubes..make sure you have adequate headroom....I use a ladder and have to jockey around a beam to get them all the way out without making a mess..fly ash everywhere...once you have it down it s a breeze...
Thanx Skfire.. Do you have any pics of your 30/50 near boiler piping and how do you find the height for boiler loading and lighting with it on the floor?On the floor...and using ladder to clean tubes..make sure you have adequate headroom....I use a ladder and have to jockey around a beam to get them all the way out without making a mess..fly ash everywhere...once you have it down it s a breeze...
Just rereading your post and thinking about "make sure you have adequate headroom". There are more than 1 or 2 things that didn't get much thought prior/during the install. Somehow I got lucky on all of them, must be some good karma from a past life but yes some thought in advance is a good thing - just hard to know all of the things one should consider. I don't want to think about what would have been required if headroom didn't allow for the turbulators to be removed. Like I said I got lucky, reading hear and taking a lot of notes is definitely recommended as I look in the rear view mirror.....On the floor...and using ladder to clean tubes..make sure you have adequate headroom....I use a ladder and have to jockey around a beam to get them all the way out without making a mess..fly ash everywhere...once you have it down it s a breeze...
you may see some here:
https://www.hearth.com/talk/threads/bolier-room-re-pipe-froling-install-pix-plbg-only-post-1.70105/
Loading. lighting no issues with boiler height...if you need anything else, please feel free to ask.
.The boiler package came withe LK 810 loading unit, which if I recall correctly has a Grundfos UPSO 65 in 115V.
If you want a specific pic let me know and I will try to dig it out and send to you.
I used the 15-42 240V for my FHG 20-30 install. It pumps 10gpm's wide open through my primary loop. I throttle it down to 4 gpm's with a Caleffi 132 balancing valve. For my 20-30 I would have preferred something with a bit less flow, but it may be about right for your 40-50. My primary loop is piped with 1", and I used a 1" caleffi 132 balancing valve. I wish I had used a 3/4" balancing valve as it would be more accurate to read in the 3-5 gpm's zone.Ya I rememeber that install now, the copper makes it look #1.. I wish I could zoom in on some of those pics.
Did you use a Grundfos UP 15-42 F in 230V for your boiler circ?
I ordered the 132 caleffi quicksetter in 1-1/4" . It was recommended by Boithermic.I used the 15-42 240V for my FHG 20-30 install. It pumps 10gpm's wide open through my primary loop. I throttle it down to 4 gpm's with a Caleffi 132 balancing valve. For my 20-30 I would have preferred something with a bit less flow, but it may be about right for your 40-50. My primary loop is piped with 1", and I used a 1" caleffi 132 balancing valve. I wish I had used a 3/4" balancing valve as it would be more accurate to read in the 3-5 gpm's zone.
