I have a new Jotul F100 wood stove coming.
Was wondering if their optional "fresh air kit" was a good idea.
I just read a pretty big thread discussion on here about how air moves in a house when heated with a wood stove.
I am a total newbie to wood stoves but it seems to me that the optimal situation is for your fire to be fed with air/oxygen from the OUTSIDE of your house if at all possible.
That would totally negate the negative air pressire created by your stove sucking up air from the INSIDE of your house (which in turn pulls in cold outside air through leaky windows and doors), would it not?
I am sure that a lot of you veterans who who have been happily heating your homes with wood stoves for years without a "fresh air kit" might have a built-in prejudice against the idea, but seriously would it not be a BETTER situation for your stove to be drawing outside air?
It just seems commonsense to me that the outside air would be better, simply an extension of the fact that a totally open fireplace is a horrible way of trying to heat your home because it is sucking huge amounts of your inside air up the chimney and creating that negative pressure situation which ends up sucking outside air into your house through leaky windows and doors, etc.
Obviously a well-designed wood stove handles the air intake situation MUCH more efficiently than an open fireplace, but alas it still does feed itself with inside air.
The outside air feeding into your stove via a fresh air kit will be much colder than the inside air - does that become a key factor in weighing the worthiness of the idea?
