I have reached the point of mind block doing research. I'm trying to heat my 1400 sq ft one story home primarily with a wood burning fire (at a minimum, 800 sq ft using wood as the primary source and the other area using the current electric split system). Currently, there is a gas insert that's not effective beyond the immediate room it's in. I have a masonry fireplace (house built in '68) that is 38" wide x 30" tall x 26" deep. The fireplace is in great shape, and doesn't appear to have been used very much (zero creosote build up).
I can't find a wood burning insert that gives me confidence that it will heat this space effectively. My budget for the entire project is $1,500. I'm planning to use a 6" stainless liner all the way up the chimney (approx 12 ft) and installing a block-off plate at the damper location. I also plan on installing a outside air source since the home is fairly air tight.
I like the looks of a free standing stove better than an insert. And, stoves appear to have larger fire boxes (I want 2+ cubic ft box at a minimum). The problem is, most stoves are at or more than 30" in height making it a tight fit at best and I don't want the stove to protrude from the fireplace opening more than 6-8 inches. Can I simply place a freestanding stove in the fireplace without legs? Or, perhaps just using 2" square steel tubing as a base? I don't need a stove with an ash pan but need to be sure the fresh air intake isn't in the bottom of the stove if I do away with the legs.
Any thoughts? Thanks!
PS - I don't like inserts that have the fan box in front with the electrical chord showing. Also, inserts seem to be more expensive than freestanding stoves.
