I will be clear cutting 1500'x 30' Hopefully ready for pickup Monday, December 7. I hired a tree removal service to drop everything and just leave it.
The area to be clear cut is about 1000' from a paved road through a flat field, however I believe a 4WD truck could drive there pretty easy. I walked it 48 hours after 1" of rain and it seemed pretty solid. Most of the trees are ash, and are mostly smaller 8"-12" diameter. I know it isn't big wood, but it's free. You'll have to limb it but you can take what you want and it is already on the ground and you should be able to drive right up to it.
I am also cutting a bigger area - 1000' x 70' with more bigger trees, however, there is a stream crossing involved and a lot of the area is wet. There is a lot more wood over there but admittedly it will be some work to get it out. There is a concrete bridge existing but it will take some work to figure out how to get over. Getting over is only half the battle - the wet ground on the other side will also be a big issue.
First come first serve. About 1 mile south of the Cabela's on at the junction of Rt 61 and I-78.
