New member & first post, so please be gentle ![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
First some background about my setup. My vacation/retirement home out here in Montana was built in the early 70's, and it has a Franklin type fireplace with swinging front doors and a screen in front and a double wall metal chimney. I'm converting it to LP in stages and am very pleased so far with the results. I'm currently using a triple pipe 18" burner rated for 75,000 BTU/Hr and an air mixer valve rated for 90,000 BTU/Hr and am feeding this with a 10 PSI Bayou Classic regulator with a downstream needle valve to control gas flow. This produces a very nice, clean flame with some blue right at the burner holes, turning to beige and yellow for the rest of the flame. No orange color and no visible smoke or soot.
I plan to replace the fixed 10 PSI regulator with either a 0-5 or 0-10 PSI adjustable regulator as the fixed 10 PSI regulator is really too much for my burner, and the flames produced by opening the needle valve more than 1/2 turn are too high. Previous to this I'd tried a fixed low pressure (11" WC) BBQ type regulator and the flames were really weak, hence the move to the high pressure regulator. Didn't have much choice in the pressure range as the Bayou Classic was the only HP regulator available locally. I do have the lower range reg's coming in from Amazon next week, however.
Now my question: The next item I want to install is a flame failure safety valve, however the commonly available valves that I've seen online are only rated to 65 mbar (1/2 PSI) so I really don't want to install one of those downstream of a 0-5 or 0-10 psi regulator as I would be decreasing the safety of the system instead of increasing it!
Suggestions/Recommendations?
