I have inherited a a Franklin Cast Products Scandia Model 315 wood stove. I have read some previous posts about the fate of the company, but have a few questions if anyone can offer info. First, a tag on the back say's it is to be used with an 8" chimney, but I have a 6" chimney...what are the problems that could result with the smaller pipe? Second, there is a sheetmetal damper on the back. Attached to the damper (but not mounted) is a chain & thermometer mechanism, plus there is sheetmetal bracket & two loose studs with threaded ends, none of these latter parts are mounted either...does anyone know how they should be mounted? Third, this is a side load unit that has a damper lever that prevents the side load door from opening unless the damper is closed. This doesn't seem right to me, but is this correct? If anyone wants to provide an email address I can send photos.
