I was hoping to sanity check my plans with the gurus on the forums! I'm planning to do a stone veneer around my zero clearance FP. My plan is to buildout the wall just a bit, by using 2x4s on face to run horizontally across the existing vertical studs (I'll go over the existing sheetock. Then I will lay 1/2" plywood over the studs (also horizontally) from ceiling to floor. I am going to replace the one wood stud with a metal stud where the top of the zero clearance fp is and use wonderboard or some backerboard instead of plywood for the heat concern. Then obvioulsy I'll put down the tar paper and lathe, scratch and set the stone. Does this sound ok so far? I also have another question that I'm hoping someone can help me with:
To maintain the symmetry of equal spacing of the veneer on both sides of the FP, The layout falls just a bit past one of the vertical studs in the framing. One the right side of the fp, i'm right on a stud. On the left side, however, I run past a stud by about 6". I see two options - one is to remove the sheetrock and put in a new vertical stud to ensure I am hitting against a stud (a lot more work but more structurally sound) or 2 - since I am running the buildout studs horizontally, I will have bearing across about 6 other studs and was wondering if I can use an anchor bolt (and maybe a dab of liquid nails) to tie into the sheetrock. Do you think hanging over by 6" and missing the stud on the left side is a big problem if I tie in with an anchor bold and given that the whole buildout should be tied together by the existing studs both horizontal and vertical, as well as the plywood, scratch coat, etc? I'm feeling like putting the stud in may be overkill but I am not sure. I'm sure this is a fairly common problem around fireplaces? Any thoughts?
PS - This finished dimensions of the veneer will be 90"w x 12' tall (its a 12' wall in a great room)
Thanks!
Rick
Thanks!
Rick
