Fourth year burning in a 42 Apex Cat stove. The issue I describe below just started a few weeks ago and is only happening when I’m burning from my pile of Ash. The Ash is two years old and is measuring 15% - 18% MC on a fresh split.
So I’ll get my fire going. Basic bottom up cold start fire. Will dial everything in with my Cat cruising anywhere between 800 - 1,000 degrees. Air at about 10 - 20%. Fire will be cruising for about 30 -60 minutes with no issues. Then the flames will go out unexpectedly and the Cat temps spike to 1,200 + degrees (inside stove glows red from Cat being so hot). Cat temps will continue to rapidly climb until I get the flames going again.
I open the air to 100% and sometimes open the bypass to reignite the flames and cool the Cat. Usually get significant blow back when the fire reignites and then I reengage the Cat and dial the temps back down.
What would be causing these flames to go out like this?
