glad I found this. I have a FireplaceX 42Apex (which is a "fireplace" but basically a wood stove in a box with a blower) and have been learning how to use it through my first winter. It's a shame how the operating manuals on these things seem to be written with experienced wood stove operators as the expected audience. I've been afraid to turn my air control down below about 40% because if I go all the way down, or even below about 25%, the flames disappear entirely and I thought I was smothering the fire and coating my flue with extra creosote. As such, I go down to where I maintain flames and I can still let it go 8-9 hours and have enough coals to reload without starting over, but I don't want to leave heat on the table and burn through wood faster than I need to.
I do have a fairly tall chimney, it's all relative but probably just under 30', but with air control fully open it burns at about the same intensity as it does with the fireplace door wide open but maybe a hint of that slow-motion flame effect, so I figure it's getting enough, but maybe I just need to find the right point in the air control.
I'm also learning how to make sure my wood is dry...started out just checking the ends but then i started probing the middle of the split face and realized some of the wood that was measuring <10% was really 15%+. The stuff I've measured between 15-20 doesn't seem to burn as readily as the <10 stuff, but I'll start checking the fresh side right after I split it and maybe I'll learn that what I've been measuring at 18 might actually be higher than that.
