I am pretty new to wood burning and have a new FP30. I have been taking it pretty easy and working my way up in load size and keeping a decent eye on things until I get a good feel for it. Since I had a fairly wide open Saturday this past weekend I decided to see how a good sized load would do and what kind of burn time I could get out of it before I would need to reload.
I started a fire around 730 or 8 and let it burn to get a good bed of coals to reload off of.
Pic #1
At 11am I gathered 6 medium splits of walnut and hard maple. I have been periodically checking these and they have been in the 14-15% range.
Pic #2
So I loaded them up E-W, and this made for a pretty full load. I definitely could fit another split, maybe two if I really worked at how I stacked them in the firebox.
Pic #3
I left the air open until I got the wood ignited pretty well, and then started shutting the air down in increments. Within about 45 minutes I was able to shut my air all the way down and have great secondaries working. And it looked like this around noon, 1hr into the burn.
Pic#4
At 230pm, 3.5hrs into the burn it was a mass of glowing logs with some faint secondaires, but mostly just glowing.
I missed a good portion of the second half since I decided to go hunt in the evening. But I asked he wife not to add any or disrupt it in any way since I was doing this to document and learn. Still looked good when I got back in around 630pm.
Pic #5
Here is a pic from 8pm. Lots of ash, one glowing remnant of a log. Still throwing tremendous heat from the front and out the second fan kit.
Pic #6 thru #8
Here is what was left at 9pm. Still putting out great heat, I believe the magnetic thermometer on the face was still around 250+ degrees. At this point I decided I would rake all the coals to the front and let them breathe a little to see how it did for a reload. There were plenty and it did great on reload. I guess I would call this 10 hours between reloads.
So, as a side note t othis, I have read on here that many who have the FP30 with an OAK have said that this unit breathes almost too well. So the solution for many has been to tape off a portion of your OAK at the exterior intake. My father stopped by around 1-2pm when I was getting awesome secondaries and he made the comment that I should shut my air down a bit more to slow down the burn and get more time out of the load. But I already had it shut down all the way. He couldn’t believe it (he has a Astria Montecito).
So we decided to tinker with the OAK intake and see what would happen. I asked him to hang out in the living room and watch the flame behavior while I went out and tried some duct tape on the intake. I had my father on the phone while I tried this and I tried everything from sealing half of it off, to taping off the whole thing, and he said the flames never changed a bit. Then when I pulled the tape off, still no change.
Does anyone have any ideas on when this is making no difference? Are there any other options for cutting the air back a bit more? What do you with experience with the FP30 think about that burn cycle? Thanks for any info or comments, I appreciate the help!
![FP30 burn cycle and air question FP30 burn cycle and air question](https://www.hearth.com/talk/data/attachments/233/233768-823c0c86a82e5a1898c7df5b5a3d2019.jpg)
Pic #1
Pic #2
Pic #3
Pic#4
Pic #5
Pic #6 thru #8
![FP30 burn cycle and air question FP30 burn cycle and air question](https://www.hearth.com/talk/data/attachments/233/233761-9b32ab2ab3665d3aeb22dc2be8359d96.jpg)
![FP30 burn cycle and air question FP30 burn cycle and air question](https://www.hearth.com/talk/data/attachments/233/233762-061769d199a2f76400d3fd2d60f49f64.jpg)
![FP30 burn cycle and air question FP30 burn cycle and air question](https://www.hearth.com/talk/data/attachments/233/233763-6fc7b662960d973031948755a3b91938.jpg)
![FP30 burn cycle and air question FP30 burn cycle and air question](https://www.hearth.com/talk/data/attachments/233/233764-e52e38055e8d5831c2cab60d71500c07.jpg)
![FP30 burn cycle and air question FP30 burn cycle and air question](https://www.hearth.com/talk/data/attachments/233/233765-6e96b5817accc70a026b1f8e30fb512d.jpg)
![FP30 burn cycle and air question FP30 burn cycle and air question](https://www.hearth.com/talk/data/attachments/233/233766-e208db2ba0c185e81d095de86bbdc954.jpg)
![FP30 burn cycle and air question FP30 burn cycle and air question](https://www.hearth.com/talk/data/attachments/233/233767-28cc4b38f3dd5a2c27d95c3e84b40d26.jpg)
