![FOUND PROBLEM NEED HELP ON PREVENTING IT,PIPE BLOCKAGE FOUND PROBLEM NEED HELP ON PREVENTING IT,PIPE BLOCKAGE](https://www.hearth.com/talk/data/attachments/154/154255-172d650d42cebb756c7bc99e88dd5c47.jpg)
really don't want to pony up $400 for a ladder from HD.what if i removed the 5ft pipe and put a simple cap on like this in picture?i have 2 buddies with wood stoves where the pipes go 30+ ft up to roof.they said they never touch them ever.what is advantage of the 5ft long pipe?.View attachment 154257
The up pipe helps create a natural draft mostly for power outages so most of the smoke will escape out of the pipe and not into your house.what is advantage of the 5ft long pipe?.
That works. Many people do it that way. But it doesn't stop the bees from getting in there as you stated. But It may be easer to reachwhat if i removed the 5ft pipe and put a simple cap on like this in picture?
Not weird at all. It would workThis may sound weird but here's what I would do. Run a cleaning brush up inside the vent and just leave it just inside the opening at the top. It should sufficiently plug your vent to keep critters out and you can just pull it when ready to burn again.
really don't want to pony up $400 for a ladder from HD.what if i removed the 5ft pipe and put a simple cap on like this in picture?View attachment 154257
Yes and too you can roll up a ball of rags and wire that on to the end of a rod . Leaves less gaps than the brush.That's a great 'thinking outside the box' solution, Tim.
It would likely require a little finagling with the cleaning rod length so you could leave the rod in the pipe, but still close off the T-cleanout to keep critters from entering from that end. If the cleaning rod length was 6" or so shorter than the vertical pipe section length you could reach up in there to pull it out, while still being able to cap the T - clean out.
Alternatively, you could cut the bottom most section of cleaning rod to length and dedicate that section 'to the cause'.
Man I screwed up last year and didn't do that, the stove looked older than my 35 yo coal stove inside when I opened it up this fall. I never did anything like that with my coal stove and it never rusted inside, I think cause it was sealed tight enough and could breath.Lets not forget DampRid in the combustion chamber.
