Found a Stihl 031 AV
08brute
89
South Dakota
Hey guys,
I found my grandpas old Stihl 031AV last night while searching for something else. The bar and chain are solid rust but the engine is not locked up. It has to be 25 - 30 years old and probably hasnt been run in 20. I looked in the cylinder and it looks like it has some nasty buildup on the top of the pistion. I started tearing into it and I had to cut the muffler in half to get the metal shards that once was the baffle out of it.
Do you think it would be worth trying to get it going? Was this a good saw in its day? What is the cc of this saw?
Does anyone know how to remove that electic chain brake that sits on the bolt that holds the bar on?
Thanks in advance for the help!
Even if it wasnt worth 10 cents to anybody else, it was your grandpa's, so how much is it worth to you to see it run again?
59 cc saw
If I understand a small bit of Stihl naming convention I believe this is the same saw as today's MS310. Great saw, in my humble opinion, since I use one.
I'd spend $50 to get that saw running in a heartbeat. Would be a great backup, extra, or maybe even a full time user....
yep 310
08brute said:
Hey guys,
If it's 25-30 years old it's a good saw. Stihl didn't used to make "home owner" grade saws. Is it "worth" getting running? That's up to you and how much is really wrong with it.
Good point! It is the saw my dad almost lost his leg with and the saw my grandpa used to clean out the grove before building his home.
I will dig into it a bit firther and see what it will take to get running. I will let you guys know how it turns out!
Thanks
