100 gallons of heating oil coming into the 550 gallon tank coming in Monday, and the tune up / overhaul of the oil burner happening Tuesday.
I thought I had 1 broken base board pipe, turns out I had 4
All a result of the bad winter 5 years ago. My former co workers / HVAC / plumbing guys came in, and saved the day. They spent 3 hours here, cutting, soldering, adding water to the system, shutting it down as we found more leaks / broken pipes, and never charged me a dime.
Burner valves opened, system is not leaking, and burner is not leaking. We did not fire it, as I stuck the tank and it's E.M.P.T.Y. I'll fill it a bit at a time, and keep it full, so as to be ready for the next Apocalypse![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Tired of running on wood alone, and all the work all by myself. *Stress on all by myself*
T stats will be set at 62, and will run the wood stoves as much as possible to off set the oil, but with the cost of oil currently, this makes sense to me. Also turning off the electric HWH, and draining it. Will keep in in reserve and at the ready if needed (turning off the valve, and throwing the breaker, as well as draining it).
I have 6 cord ready to roll, and another 6 that needs to season and / or be split / cut / stacked. I can take my time with this, and still be ahead when things go south, which they will![Mad :mad: :mad:](/talk/styles/default/xenforo/smileys/angry.gif)
Actually looking forward to the break, it's been a rough 5 years!
![Confused :confused: :confused:](/talk/styles/default/xenforo/smileys/confused.gif)
