Just wondering how many people out there are using forced air wood furnaces, as opposed to regular stoves? I have the Charmaster Wood Controls system. Would like to discuss a few things since I have not had the system long (1 month).
Your set is almost the same as mine but i think my stack temp are lower when the fan not running. Just got a thermometer. With the barometric damper how far does that open. I get croastoe build up on the damper flap itself that I chip off.laynes69 said:The forced draft is a small fan on a thermostat upstairs that forces oxygen into the fire to fuel it up if the house drops to the temp set. Ours rarely runs, as far as stack temps, I have no idea, but would say most defiently over 300. We have a barometric damper on our flue due to a tall masonary chimney. 90% of the time when the furnace is burning only vapor comes from the chimney. I checked the flue the other day and after almost a month the buildup was less than an 1/16 of an inch. Nothing in the chimney.
Eric Johnson said:Anybody who tells you that it's better to burn green/wet wood than dry wood in any stove, furnace or boiler, doesn't know what he's talking about.
