elkimmeg said:
goose are you adviing this guy to install a stove that does not meet the listing requirements? Verticle heigh is a listing requirement needed to be obtained to pass inspections.
First of all I would not have issued a permit if the verticle height could not be satisfied. Are you advising of a non compliant .non permitted, listing violation. installation ?
We are not talking about 6" but 5.' Are you willing to take on the responsibility, when that chimney does not produce enough draft and tell him his home filled up with smoke and carbon monoxide its ok?
Well, according to the OP, the extendaflue that you are reccomending at 40" max extension is not going to be compliant either.... (5 feet = 60")
What I was reccomending was EXPERIMENTATION - there is an outside shot that a short flue that is otherwise OK (he does have the right X section diameter, meets the 2/3/10 rule, and the chimney's at least protected from the wind) MIGHT work, and if not I was suggesting he try TEMPORARY extensions to see how much length he needs to get a *functional* setup. THEN making whatever permanent changes he would need to get that amount of extension....
I may be misinterpreting the manual, but when I see them talking about chimney height, they say "RECOMMENDED minimum height" - they did NOT say that this was a required height the way they say that clearances are REQUIRED.... My usual interpretation is that when something is "reccomended" it is considered desirable, but is not an "absolutely must have". IOW, I don't thing VC is saying that the stove would be unsafe or not work with an 11' chimney, but that they think a 16' or higher chimney is best.... I did NOT see a listed REQUIREMENT for a minimum vertical height (and note that their recomendation changes with altitude, something that the OP hasn't even mentioned)
I don't know what the "minimum stack height" is on my smoke dragons, but I had quite a nice draft with a FOUR foot high stack at one point when I was testing it outside, in warm weather... I also see lots of single story ranches with chimneys that certainly don't look like they came off of factories, so I feel sure that at least some homes may draft allright with shorter than reccomended chimneys.
I didn't define conditions when experimenting, but that usually would imply extra levels of alertness, and doing small fires that could be dealt with if a given test did not work... Obvioiusly getting smoke and CO in the house is not OK, this is why I said TEST to find out what is needed to NOT get smoke and CO problems. (Something that neither you or any of the other extendaflue advocates suggested.... ) I do not think it makes sense to go out and spend $800 on a 40" extendaflue (that still doesn't bring him up to the reccomended 16') without evidence that doing so would actually give him a working installation.
If I was in his shoes, I would probably get a few peices of 6" single wall and stick it into the top of his chimney on a TEMPORARY basis. (If I could figure a way to secure it adequately, I might use 8/8 flue tile instead)I'd try that in different lengths until I found what length gave me a properly drafting chimney - and then modify the existing chimney IN A COMPLIANT MANNER to give me that height - the end result is a compliant installation that WORKS, without wasting money on expensive approaches that might not be adequate.
Instead of flaming me about suggesting that the OP might want to experiment before spending lots of money, you might have answered the question I raised about IF he decided to extend the masonry chimney to give him more height would he need to replace his entire liner, or would it be OK to splice another peice onto it? IMHO that would be more useful...
Gooserider
