With the GARN 2000 I've been advised to keep the flue temp between 300 and 400 degrees.
What's happening if it's higher or lower?
Does lower mean either I'm burning wood with too much moisture, thus increasing the chance of Creosote, or the fire is too small?
Can the temps get much higher? I'm (usually) burning very dry wood (inside shed 5 years)...even then the flue temp is usually in the high 300's with a good fire going.
