I have a Vogelzang defender epa certified tube stove. I have been watching the flue temps via the magnetic style pipe thermometer. I put it at the 18" above the stove all seems good when she is shut down, no smoke, secondaries firing nicely, 2 year seasoned ash and hard maple. The issue is the thermometer is reading really low likeright around 300 or a touch lower. It is cranking out the heat when she is shut down. Do you think I'm building lots of creosote being that cool or thermometer isn't really positioned right? I figured the thermometer is pretty fool proof if you follow the directions. I do have a step on the top of the stove maybe ill try moving it down to 18"off the lower step.
![Flue temps vs creosote build up Flue temps vs creosote build up](https://www.hearth.com/talk/data/attachments/197/197684-7821148f2e95f096f0c79b44de9124ef.jpg)
Sent from my SM-G930V using Tapatalk
