have about 34 to 35' of chimney length interior with uninsulated liner should i add key damper.doesn't seem to be a problem ,but could be missing something.suprised that wind actual reaches stove lol nothing major but you see flames flicker
The wind isn't reaching your stove. It is either effecting house pressure and therefore the fire or effecting draft blowing over the top of the chimney. Can you control your stove properly? Meaning keep the flue temps down where they should be and get the burn times your supposed to? If not a key damper will help
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
